Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Cisco ASA 5510 Regular static Nat is not working
We have Cisco ASA 5510 Firewall
Having 4 public ips in which 3 are working without any issues.
The 4th public ip previously working but suddenly it stoped.
it will work only if i connect the cable to LAN and Manually assign the Public IP.
My ASA Regular Static Nat configuration:
access-list 101 extended permit ip any host X.X.X.X
static (inside,outside) X.X.X.X 10.10.3.7 netmask 255.255.255.255
Community Member
Hi,If configuration as same
If configuration as same as ealier when every thing was working fine and no other configuration changes are made on firewall during that time period, thats mean to issue with configuration. Just do reconfigure specific part of configuration that you mentioned above, I hope it will work.
Don't forget to rate helpfull posts.
Sajid Ali Pathan
Community Member
The other public ips are
The other public ips are working with the same configuration.
But only one ip having issues
Community Member
Hi,I got you reply on email
I got you reply on email but not on support forum, I don’t know what bug is this with cisco community. Leave it, come to the point:
I understand you next question, you have to do as i said, Just reconfigure static net for problematic IP.
Sajid Ali Pathan
Community Member
yes i tried so many times but
yes i tried so many times but still nothing.
Community Member
do i need to remove all the
do i need to remove all the access-list configuration?
i means remove all and reconfig it again .. Will work?
Please reply
244
