Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Cisco ASA 5515 8.6 Simple Nat Issue
Recently I upgraded several appliances from the old Pix 501 to 5515. I am struggling trying to simply set up a static route.
On the old routers I would enter the command as such
         access-list outside_access_in extended permit tcp any host 8.8.8.8 eq 3391
          static (inside,outside) tcp interface 3392 10.0.0.52 3391 netmask 255.255.255.255
Boom done!
On 8.4 I thought:
          object network Remotepc3391
          host 10.0.0.52
          object-group service remote3391 tcp
          port-object eq 3391
          access-list outside_access_in extended permit tcp any eq 3391 any eq 3391
          nat (Inside,Outside) source static Remotepc3391 Remotepc3391 service 3391 3391
But it does not work. I am sure I am missing something stupid but I can't see what. So can someone please simply convert the above command for my old firewall to the correct commands for my new firewall. Once I see it properly done I am sure it will click.
Thanks.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Super Bronze
Try the following
object network REMOTEPC
host 10.0.0.52
nat (Inside,Outside) static interface service tcp 3391 3391
access-list outside_access_in remark Allow TCP/3391
access-list outside_access_in permit tcp any object REMOTEPC eq 3391
Depending on how you have configured the rest of your NAT we might need to make modification so that they dont override this NAT configuration.
- Jouni
Super Bronze
Try the following
host 10.0.0.52
- Jouni
Community Member
Re: Cisco ASA 5515 8.6 Simple Nat Issue
Thanks Jouni I tried that and it works perfect!
362
