Cisco ASA 5525-X alarm led on
castellotti
I have installed 3 cisco asa 5525-x. One of these has the alarm led on. I take a look in the troubleshooting guide and I found to run show environment and
show controller pci.
Everything seems ok with this command.
The firewall is working but I would like to understand if there is some problem (hardware or software).
OS version is 9.
Can someone help me in suggesting other command to run?
Alessandra
14 Replies 14
alagu.raja
I have the same problem too. But from my understanding
you should have dual power supplies. If you have just one, install the redundant power supply and test.
and check what type of PCI card you installed. blank module or something with cable?
I did these and then the alarm went off.
Alaguraja.K
I am having the same problem on a 5512-X... any suggestions? Thx
Hi all,
Me too with 5512X. any suggestions? possible bug or cosmetic problem?
sh controller pci
  PCI Evaluation Log:
    1.) System is not fully operational - The PCI device with vendor ID: 0x1000 (LSI) device ID: 0x0a05 (Accelerator) could not be found in the system.
  PCI Bus:Device.Function (hex): 00:00.0 Vendor ID: 0x8086 Device ID: 0xd130
    PCI Configuration Space (hex):
    0x00: 86 80 30 d1 00 00 10 00 11 00 00 06 10 00 00 00
    0x10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0x20: 00 00 00 00 00 00 00 00 00 00 00 00 5b 10 61 0d
    0x30: 00 00 00 00 40 00 00
I am having the the same issue with a Cisco ASA 5512-X.
The alarm LED is solid amber. The commands "show environment" and "show controller pci" are all ok.
We also have two Cisco ASA 5515-X in active/active multiple-context mode, their alarm LED is off.
Any suggestions?
This may be because of IPS issue.
Please check:
sh module ips det
I don't know if this is a question for me. But in my case we don't have IPS, if I run the command "show module module ips detect" I get the following output:
HOSTNAME(config)# sh module ips details
Getting details from the Service Module, please wait...
Unable to read details from module ips
Card Type:          Unknown
Model:              N/A
Hardware version:   N/A
Serial Number:      ABCDEFGHIIDDENMYME
Firmware version:   N/A
Software version:
MAC Address Range:  a80a.0aa1.4146 to a80a.0da1.4146
Data Plane Status:  Not Applicable
Status:             Unresponsive   No Image Present
License:            IPS Module  Disabled  perpetual
HI
If this device is in production, please arrange a downtime and unplug the power and wait for 30 sec, then power on the device again.
If this works then there may be was a false alarm was on.
Please share the update.
That did not fix the problem. This is a brand new ASA laying on my desk serveral times. It has been shutdown multiple times to store it for the evening. The alarm LED is still there.
 Hello !
I had the same problem on my ASA 5525-X:
Help please!
BINH_C_LE83
try installing an ASA-IC-B-BLANK (the one with a regex ribbon cable).  Had a similar problem and that was the solution.
Aissatou
Hello !
Help please!
Have a same problem. How I can resolve it?
dpas
Does anyone know where the ASA PCI ribbon cable can be purchased from?
This seems to be cause of the alarm. After checking there was a slite cut on ribbon cable not making the full connection, after removing and boot. Alarm came up. Per sh controller pci details.
"1.) System is not fully operational - The PCI device with vendor ID: 1x1000 (LSI) device ID: 0x0a0 (Accelerator) could not be found in the system.
Thisnisnthe ribbon cable that connectes the accelerator board infront of the unit with the pci plane addon.
Part# 35101NC00-01G-G Other part ID white sticker: 74-9917-01 BO
Active Riser Cord
