Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Cisco asa 5525-x firewal Management interface
Hi guys
             please I need some help on asa 5525-x management interface, I changed the ASA default management ip address of 192.168.1.1 to an IP address that was NATed through a router from another subnet.
I was able to ping the replacement IP of the firewall management IP and when I try to connect from the browser it showed the connection was ok, but afer clicking on continue to this website(not recommended) I get the following....404 not found.....The requested URL/admin/public/index html was not found in this server.......Any help will be appreciated ...Thanks
1 REPLY
Bronze
Anthony,
You may need to conect via console and collect the show ver and show run, the new IP range must be allowed on the HTTP commands, otherwise you wont be able to get access.
Juan Lombana
Please rate helpful posts.
275
