Cisco ASA 5540s not HA not working on Standby ASA
I have two Cisco ASA 5540s that i want to cluster... here are the basic that I have covered thus far:
Code is the same for both units, failover configs, and mgmt interfaces are up and up.
I have not connected either FW to the network yet... should failover work without the ASAs being connected to the network?
I would have thought that I could do my initial config and then pair them up to get the config to sync.
I have tried a crossover and straight through cable to no avail.
Primary ASA:
P10-CORP-ASA# show failover
Failover On
Failover unit Primary
Failover LAN Interface: StatefulFO Management0/0 (Failed - No Switchover)
Unit Poll frequency 2 seconds, holdtime 6 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 1 of 210 maximum
failover replication http
Version: Ours 8.2(5)41, Mate Unknown
Last Failover at: 17:45:04 UTC Jul 15 2013
        This host: Primary - Active
                Active time: 9030 (sec)
                slot 0: ASA5540 hw/sw rev (2.0/8.2(5)41) status (Up Sys)
Secondary ASA:
P10-CORP-ASA# sh failover
Failover On
Failover unit Secondary
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Policy 1
Monitored Interfaces 0 of 210 maximum
Last Failover at: 19:56:44 UTC Jul 15 2013
        This host: Secondary - Standby Ready
                Active time: 136 (sec)
Primary Failover Config:
failover
failover lan unit primary
failover lan interface StatefulFO Management0/0
failover polltime unit 2 holdtime 6
failover link StatefulFO Management0/0
failover interface ip StatefulFO X.x.x.x. x.x.x.x standby x.x.x.x
Secondary Failover Config:
failover
failover lan unit secondary
Mgmt Ports:
Active:
interface Management0/0
description LAN/STATE Failover Interface
speed 100
duplex full
management-only
Secondary:
speed 100
duplex full
management-only
  • Firewalling
1 ACCEPTED SOLUTION
Hello Shawn,
Is highly recommended (not to say a MUST) to use an interface for the failover link with the capacity similar to the ones that will be handeling traffic so in this case managment interface 0/0 is not a good option,
Altough using the managment interface is an option but can u remove the following
interface managment 0/0
no managment-only
This on both sides,
Let me know
For Networking Posts check my blog at http://laguiadelnetworking.com/
Cheers,
Julio Carvajal Segura
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Or should I try another interface on the ASA... as i mentioned these are not connected to the network.
outside interface nor any other interface.
Hello Shawn,
no managment-only
This on both sides,
Let me know
Cheers,
Did not work... i blew away the failover configs and the int M0/0 configs too... and reapplied the configs minus the management-only on the interfaces still did not work.
I connected both the Active/Standby and still wont detect each other.
I also attempt to force failover by doing the 'failover active/ no failover active to no avail.
Failover surely should work withoug ASAs interfaces being connected anywhere. Interface, dedicated for failover shouldn't be management only.
Failover config u have now seems to be ok.
Try using different debug fover commands to see what's actually happening.
Issue was a faulty x-over cable... once i did that... the config sync occurred and i was able to test Active/Standby
respectively for both units.
Issue is RESOLVED.
Hello Shawn,
Great to hear that,
Some kudos to you
Please mark the question as answered so future users having the same issue can see what was your solution
Cheers,
no management only and use a cross over cable and that will fix!
449
