Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Cisco ASA 5550 problem
Sorry if this i a silly Q, but im normaly only dooing IOS config.
I have little problem when trying to setup this unit.
It boots ASA software 8.0.4 fine.
When i go to enable mode and into configuration mode and try to configure ip on an interface i have a problem.
ciscoasa(config)# int
ciscoasa(config)# interface man
ciscoasa(config)# interface management 0/0
ciscoasa(config-if)# ?
Interface configuration commands:
  default      Set a command to its defaults
  description  Interface specific description
  dhcp         Configure parameters for DHCP client
  duplex       Configure duplex operation
  exit         Exit from interface configuration mode
  help         Interactive help for interface subcommands
  no           Negate a command or set its defaults
  shutdown     Shutdown the selected interface
  speed        Configure speed operation
I am not allowed to set anything on this interface, same goes for the 8 Giga interfaces on the unit.
I did try to upload the new software 8.4.2 from rommon using TFTP.
It boots 8.4.2 fine, but  have same problem as in 8.0.4.
I did try to create a user haveing priv 15 and logging on as that user. It gives the same.
The firewall is not in transparent mode.
Anyone who knows what i am doing wrong.
Hello Jaynet,
There are no silly questions, can you do a sh mode and provide us the output.
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
:-p
Okay, i did not se that one comming.
I was in multible mode. After a change to single mode and a short reboot. Everything was back to the way i was use to.
Thanks for the help..
Hello Jaynet,
Good to see that now everything is back to normal.
Please mark the question as answered.
Best regards,
Julio
Julio Carvajal
395
