Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Cisco ASA 5550 static NAT problem
I have 1 problem in configuration which normally worked on PIX 6.3(1) but showing Warning message during implementation on ASA.
I have 2 statics:
static (dmz,outside) tcp XXX.XXX.XXX.XXX 8080 YYY.YYY.YYY.YYY 8080 netmask 255.255.255.255 0 0
static (inside,outside) tcp XXX.XXX.XXX.XXX https ZZZ.ZZZ.ZZZ.ZZZ https netmask 255.255.255.255 0 0
Public ip XXX.XXX.XXX.XXX is the same, private ips in inside and dmz is different
The second static ASA not allowing me to enter: Warning: conflict with previous static
On Pix 515 v.6.3(1) this configuration worked very well.
Is there any trick to start this work??
Thanks. Alex
Green
Re: Cisco ASA 5550 static NAT problem
Do you have another static with ZZZ.ZZZ.ZZZ.ZZZ?
Community Member
ZZZ.ZZZ.ZZZ.ZZZZ is internal ip, there is no any other static configured for it.
Error showing problem of XXX.XXX.XXX.XXX IP address conflict
376
