Cisco ASA 8.2 55xx connect 2 inside interfaces together
Hi all,
I have some problem with my Cisco ASA 8.2 5510. I have to know how shoud i connect 2 inside interfaces together. I am writing what i have.
I have 5 network connection on Cisco ASA.
1. Interface Ethernet 0/0 - outside 200.200.200.200 255.255.255.240
2. Interface Ethernet 0/1 - 1_firm 10.0.1.1 255.255.255.0
3. Interface Ethernet 0/2 - 2_firm 192.168.1.1 255.255.255.0
4. Interface Ethernet 0/3 - DMZ-Server 10.10.10.1 255.255.255.0 (Just one Server)
5. Management -  no need
I have to connect 2 Interfaces, (1_firm) with Interface (2_firm). I've tried
"route 1_firm 192.168.1.0 255.255.255.0 10.0.1.1" ,
but i resiving following error "Cannot add route,connected route exists".
But i have no route configuration. What i have cheking? Or maked i some wrong?
Thank you for your help
1 ACCEPTED SOLUTION
Here is the static NAT configuration:
static (vpm,wundplan) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
Then "clear xlate". You should be able to access the 2 inside interfaces.
What are the security levels on those interfaces? You would need to configure NAT exemption, or static to itself for those network to be able to connect to each other.
Please share your current config and we can check if there is any missing configuration.
Hi Jennifer,
Thanks for your answer.
Sec. Level 90 .
Can you write me correct NAT and exeption configuration? That is my conf.
This is my test Firewall system
ciscoasa(config)# sh run
: Saved
ASA Version 8.0(2)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0/0
nameif outisde
security-level 0
ip address 200.100.100.200 255.255.255.240
interface Ethernet0/1
nameif vpm
security-level 90
interface Ethernet0/2
nameif wundplan
security-level 90
ip address 10.0.1.1 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/4
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/5
shutdown
no nameif
no security-level
no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
boot config disk0:/.private/startup-config
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
port-object eq https
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list wundplan_access_in extended permit ip 10.0.1.0 255.255.255.0 any
access-list vpm_access_in extended permit ip 192.168.1.0 255.255.255.0 any
access-list outisde_access_in extended permit ip any 200.100.100.192 255.255.255.240
access-list wundplan_nonat extended permit ip 192.168.1.0 255.255.255.0 10.0.1.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu outisde 1500
mtu vpm 1500
mtu wundplan 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-625-53.bin
no asdm history enable
arp timeout 14400
global (outisde) 101 interface
global (wundplan) 1 10.0.1.0 netmask 255.255.0.0
access-group outisde_access_in in interface outisde
access-group vpm_access_in in interface vpm
access-group wundplan_access_in in interface wundplan
route outisde 0.0.0.0 0.0.0.0 200.100.100.199 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.0.1.0 255.255.255.0 wundplan
http 192.168.1.0 255.255.255.0 vpm
http 10.0.0.0 255.255.255.0 wundplan
http 192.168.0.0 255.255.255.0 vpm
http redirect wundplan 80
http redirect vpm 80
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:5cd35a1417360a176153562a9c67e266
: end
Thynk you very mach.
Hi Jenifer,
I have one good Idea. If you have Time we cann with Team Viewer connecting. What are you seing?
THANK YOU VERY VERY MUCH !!!!! YOU SAVED MY LIVE THANK YOU !!!!!!!!!!!!!!
Have a nica day!!!
1046
