Cisco ASA 8.4.3: Infinite SunRPC inspection timeout possible?
Hello!
We have an ASA5520 firewall which is used to secure some servers in the office. One server in the DMZ is accessing a NFS share on a higher security-level interface.
To make this work, we have allowed port 111 and enabled sunrpc-server as well as protocol inspection.
So far so good.
The mount and operation works fine but after <timeout> the session on the ASA gets closed.
This happens even if there is continous traffic via NFS.
The timeout setting seems to be an overall timeout for the translation and not only an idle-timeout (which would make sense)
configure mode commands/options:
  timeout  Idle time after which the hole for the SUNRPC service traffic will
           be closed
How can I make the translation permanent, NOT timeouting after a fixed time?
Configuring 00:00:00 as timeout setting is not accepted in the CLI
Thank you and best regards,
Bernhard
Everyone's tags (3)
Super Bronze
Re: Cisco ASA 8.4.3: Infinite SunRPC inspection timeout possible
Seems to be possible
Cisco material states the following for your software version
timeout {conn | floating-conn | h225 | h323 | half-closed | icmp | mgcp | mgcp-pat | pat-xlatesip | sip-disconnect | sip-invite | sip_media | sip-provisional-media | sunrpctcp-proxy-reassembly | udp | xlate} hh:mm:ss
sunrpc
Specifies the idle time after which a SUNRPC slot will be closed,  between 0:1:0 and 1193:0:0. The default is 10 minutes (0:10:0). Use 0 to never time out a connection.
- Jouni
I saw that but how do the settings correlate to each other?
Per sunrpc-server timeout setting e.g.
sunrpc-server intdmz 10.1.2.3 255.255.255.255 service 100005 protocol TCP port 111 timeout 02:00:00
and the global setting
timeout sunrpc 0
In my understanding it would make far more sense to have the global setting as default but with the ability to specify an optional timeout, for example:
Global timeout set to 30 minutes:
timeout sunrpc 00:30:00
Protocol inspection without timeout setting (uses global value, RFE)
Protocol inspection with individual timeout setting
Protocol inspection with infinite timeout setting (RFE)
sunrpc-server intdmz 10.1.2.3 255.255.255.255 service 100005 protocol TCP port 111 timeout 00:00:00
This will not break any existing configurations from previous ASA software releases.
Feedback welcome.
Best regards,
Bernhard
Some additional informations:
I just configured "timeout sunrpc 0" and in the sunrpc-server statement a timeout of 10 minutes.
After exactly 10 minutes the client reports error messages and the session on the ASA is closed ("sh sun ac")
What to do?
1660
