Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Super Bronze
Cisco ASA - 8.4(3) - PCTV Not working
I have an ASA 5505 running 8.4(3) at home and I'm banging my head against the wall trying to get the PCTV working from my local ISP.
Basically I open a web page for the service and I can stream all the basic TV channels to my PC screen.
I just simply cant get this working through the ASA.. Ofcourse doesn't help that I know absolutely nothing about voice/video in networking.
My setup regarding ASA configurations are as follows
interface Vlan1
description LAN
nameif LAN
security-level 100
ip address
igmp forward interface WAN
interface Vlan10
description WAN
nameif WAN
security-level 0
ip address dhcp setroute
interface Ethernet0/0
description WAN Access
switchport access vlan 10
interface Ethernet0/1
description PC1
interface Ethernet0/2
description PC2
object network LAN-PAT
nat (LAN,WAN) dynamic interface
access-list LAN-IN extended permit ip any
access-group LAN-IN in interface LAN
I can get the PCTV working if i bypass the ASA. I can for example get the PCTV working on PC2 if I simply change the port Ethernet0/2 to access vlan 10. So theres just simply something that I havent configured on the ASA or the ASA doesnt support something?
I took a capture from my PC2 just as I opened the browser and connected to the PCTV url (opens our local channe 1 right away)
Only thing I can see in the capture at that point is:
- V2 Membership report / Join group
- Right after a remote host from the ISP networks starts sending the stream with the destination port udp/2000 with the destination address of
Any suggestions on what I could check in my configuration? Or is there something that I have simply configured wrong already on the partial configuration shown above?
Please ask for any additional information you might need.
- Jouni
Super Bronze
Re: Cisco ASA - 8.4(3) - PCTV Not working
If I try to configure the following in the ASAs WAN interface
ASA(config-if)# igmp join-group
I get and message
%Exclude mode join on WAN ignored for SSM group
And I have no idea what it means.
When I have "debug igmp" on I can every now and then see messages: "Report has illegal group address x.x.x.x" just after a "Reveived v2 report on LAN from y.y.y.y for x.x.x.x"
Super Bronze
Oh well,
This is just stupid.
Found this on a Cisco document:
FWSM/ASA does not support 232.x.x.x/8  subnet as a group number as it is reserved for ASA SSM. So FWSM/ASA  does not allow this subnet to be used or traversed and mroute does not  get created. But, you can still pass this multicast traffic through  ASA/FWSM if you encapsulate it in GRE tunnel.
So basicly no deal for PCTV through with my current setup.
- Jouni
Can you NAT multicast?     ;-)
Please remember to rate useful posts, by clicking on the stars below.
