cisco ASA 8.6 configuration issues
Hello all ,
                                             internet router-----------outside------------- ASA -------inside-------------cisco 3750 (----A----)
        DMZ
        Cisco  3750 (-----B---)
1- switch A -- wireless User + Cisco Wireless Ip phones
2- Switch B -- CUCM
Problem discriptiom :
--- from switch A i can not ping SwitchB (DMZ) so ip phones can not reached to CUCM
--- on switchA 4 VLANS are configured with Different SSIDs and internet is working fine .
--- on Switch A   i want 2 VLANs (vlan60 and vlan 80) to communicate with DMZ also (Not working )
## some relevent Config is as under :
SWITCH A CONFIG
vlan internal allocation policy ascending
          interface FastEthernet0
           no ip address
           no ip route-cache cef
           no ip route-cache
           shutdown
          interface GigabitEthernet1/0/1
           switchport access vlan 60
           switchport mode access
           spanning-tree portfast
          interface GigabitEthernet1/0/23
           description **connected to ASA-Inside**
           switchport access vlan 100
interface Vlan10
           ip address X.X.100.5 255.255.255.0
          interface Vlan50
           ip address X.X.6.12 255.255.255.0
          interface Vlan60
           ip address X.X.8.251 255.255.255.0
          interface Vlan80
           ip address X.X.10.251 255.255.255.0
          interface Vlan100
           ip address X.X.20.1 255.255.255.0
          ip classless
          ip route 0.0.0.0 0.0.0.0 X.X.20.2
ASA CONFIG
interface GigabitEthernet0/0
nameif inside
security-level 100
ip address X.X.20.2 255.255.255.0
interface GigabitEthernet0/2
nameif DMZ
security-level 50
ip address X.X.21.2 255.255.255.0
interface GigabitEthernet0/5
nameif outside
security-level 0
ip address 192.168.2.5 255.255.255.0
object network IN-OUT
subnet 0.0.0.0 0.0.0.0
object network W-PHONE
subnet X.X.10.0 255.255.255.0
object network BECA-WIRELESS-USER
subnet X.X.8.0 255.255.255.0
pager lines 24
nat (inside,outside) source dynamic IN-OUT interface
nat (inside,DMZ) source dynamic W-PHONE interface
nat (inside,DMZ) source dynamic BECA-WIRELESS-USER interface
route outside 0.0.0.0 0.0.0.0 192.168.2.1 1
route inside X.X.6.0 255.255.255.0 X.X.20.1 1
route inside X.X.7.0 255.255.255.0 X.X.20.1 1
route inside X.X.8.0 255.255.255.0 X.X.20.1 1
route inside X.X.10.0 255.255.255.0 X.X.20.1 1
timeout xlate 3:00:00
switch B
interface GigabitEthernet1/0/17
         switchport access vlan 50
         switchport voice vlan 20
        interface GigabitEthernet1/0/18
interface Vlan10
         ip address X.X.100.1 255.255.255.0
        interface Vlan20
         ip address X.X.7.1 255.255.255.0
         ip helper-address X.X.6.6
        interface Vlan50
         ip address X.X.6.30 255.255.255.0
        interface Vlan60
         ip address X.X.8.252 255.255.255.0
        interface Vlan101
         ip address X.X.21.1 255.255.255.0
        ip forward-protocol nd
        ip http server
        ip http secure-server
        ip route 0.0.0.0 0.0.0.0 X.X.6.4
        ip route X.X.6.0 255.255.255.0 X.X.21.2
        ip route X.X.7.0 255.255.255.0 X.X.21.2
1 REPLY
VIP Green
We would also need to see the ACL configuration of the ASA as this is what actually controls the flow of traffic, that is if routing is correct which it seems to be from your configuration.
What you can do is run a packet-tracer on the ASA to see if the packet is allowed through the ASA:
packet-tracer input inside tcp 12345 detail
This should give you an indication where or if there is a misconfiguration on the ASA.
Please post the output here if you require further assistance.  Also a full ASA configuration (remove public IPs and passwords) would help to identify the issue.
Please remember to rate and select a correct answer
-- Please remember to rate and select a correct answer
76
