Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Cisco ASA Active/Active configuration help
I would like to know the configuration of Cisco ASA Active/Active. Since active/active works in multiple context mode. i was trying to configure one firewall as primary but i was not able to provide ip address for the interfaces. The command is not getting recognised the moment i changed the mode to multiple.
Hall of Fame Super Blue
Re: Cisco ASA Active/Active configuration help
What command are you typing in and more importantly where are you typing it in. Once you change to multiple context mode you will need to make sure you are in the right context when you are on your ASA device.
When you initially connect to the ASA in multiple context mode you will be in system execution space. You cannot assign IP addresses here. You need to change to the relevant context.
Jon
Silver
Following link should be helpful-
Configuring Active/Active Failover:
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_7_2/conf_gd/general/failover.htm#wp1096075
Hope that helps.
Vibhor.
326
