Cisco ASA Active/standby failover
Hi ,
I had an issue on testing the failover when only one interface in active unit fails.
The configuration guide mention that by default, single interface failure can trigger failover,
however,it didn't work during my testing. instead, two interfaces failure can trigger failover.
I have set the interface policy number of failed interfaces that triggers failover to "1" or "10%" , it didn't work.
Can anyone advise ?
Use
show monitor-interface
The interface shown under this will trigger failover.
You can add or remove interface by
monitor-interface if_name
no monitor-interface if_name
Super Bronze
Also, to my understanding by default if you have a single interface (without subinterfaces) it will cause a failover
If you happen to have that single physical interface configured as Trunk (with subinterfaces), it wont trigger a failover.
The above mentioned monitor-interface command in that situation enables the failover monitoring for the subinterfaces on the trunk.
- Jouni
270
