Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cisco ASA connection dropping
I have a Cisco ASA 5505 - 50 VPN edition.  I have baffling network issues that I have not been able to pinpoint and I recently started to think it may have something to do with my ASA.  I'm a network administrator and I have a Cisco ASA 5505 in my home network so I can learn how to manage Cisco ASA's and utilize the Easy VPN feature so I have a always on VPN connection into work to log into servers, etc.  I've been using the ASA for almost 6 months with the EasyVPN feature with no issues.  My ISP is Comcast.
Within the last week my connections have been randomly dropping for about 20 seconds and then reconnecting.  I have two computers on the network that have a direct ethernet run to the switch ports on the back of the ASA.  When the connection drops, I see my LAN icons completely lose connectively (yellow exclamation warning) then after 20 seconds, reconnect.  This is very random.  I was able to get it to happen every time I connected to XBOX live and play a online game.  It would almost on cue drop after 30 minutes of online gamming.  Here are the steps I have taken:
1. Replaced 10/100 switch to a brand new 10/100/1000 switch from computer run in my office to the ASA.
no joy
2. I upgraded the ASA to the most recent firmware: ASA Version 8.4, ASDM Version 6.4
no joy
3. I had an ethernet run under my carpet to the office, I started to  think that maybe one of the cables had an issue after walking on it and  vacumming causing a short.  I removed all the ethernet under the carpet and installed power line over ethernet adapter from the ASA to my office.
no joy
4. I checked both computers on the network for viruses.  All computers came back clean after scanning wth Malwarebytes and SuperAntispyware.
5. I've watched the logs on the ASA as the LAN connection drops and I don't see error messages that help me troubleshoot this issue.
The only thing left to replace is the Comcast modem or the Cisco ASA.  The Comcast modem is newer and only about 1 year old (rented from Comcast).  Since my actual LAN connection drops and I lose connectively I believe there may be some issue with the ASA or the ASA switch ports or some sort of internal hardware issue on the ASA.  Can anyone point me in the right direction?
Everyone's tags (3)
I've been monitoring the ASA real-time log and get "System Memory usage reached 81%" every 5 mintues.  The memory usage stays pretty steady at 81% even after a ASA reboot.  During the monitoring it only reached 82% at it's max.  I'm assuming the new 8.4(1) OS i'm running on the ASA eats up the memory.  Should I be concerned at the memory usage?  Here is my show memory detail output:
Result of the command: "show memory detail"
Free memory:                        49104648 bytes (18%)
Used memory:
     Allocated memory in use:       59947256 bytes (22%)
     Reserved memory:              159383552 bytes (59%)
Total memory:                      268435456 bytes (100%)
Least free memory:         49040784 bytes (18%)
Most used memory:         219394672 bytes (82%)
MEMPOOL_DMA POOL STATS:
Non-mmapped bytes allocated =     39583744
Number of free chunks       =           51
Number of mmapped regions   =            0
Mmapped bytes allocated     =            0
Max memory footprint        =     39583744
Keepcost                    =     22542768
Max contiguous free mem     =     22542768
Allocated memory in use     =     17025048
Free memory                 =     22558696
----- fragmented memory statistics -----
fragment size       count          total
    (bytes)                        (bytes)
           16             1             16
           32             1             32
           48             1             48**
           48             1             48
           88             1             88
          112             1            112
          184             1            184
          256            40          11488
          384             1            384
          512             1            640
         2048             1           2624
     22542768             1       22542768*
*  - top most releasable chunk.
** - contiguous memory on top of heap.
----- allocated memory statistics -----
    (bytes)                        (bytes)
           56             1             56
           96             3            288
          112             1            112
          152             2            304
          168             5            840
          232             1            232
          248             1            248
          256            11           2816
          512             9           4608
          768             3           2304
         1024            72          73728
         2048             1           2048
         4096             3          12288
         8192             2          16384
        12288             1          12288
        16384             3          49152
        24576             6         147456
        32768             5         163840
        65536            12         786432
        98304             6         589824
       131072             1         131072
       196608             2         393216
       262144             3         786432
       393216             1         393216
       786432             1         786432
      1048576             1        1048576
      1572864             1        1572864
      2097152             2        4194304
      3145728             1        3145728
MEMPOOL_GLOBAL_SHARED POOL STATS:
Non-mmapped bytes allocated =    109051904
Number of free chunks       =          284
Max memory footprint        =    109051904
Keepcost                    =     48865136
Max contiguous free mem     =     48865136
Allocated memory in use     =     59947256
Free memory                 =     49104648
    (bytes)                        (bytes)
           16            83           1328
           24            74           1776
           32            48           1536
           40            39           1560
           48             1             48**
           48            15            720
          512             2           1424
          768            10           7952
         1024             2           2272
         4096             5          24200
        24576             3          87416
        98304             1         108976
     48865136             1       48865136*
    (bytes)                        (bytes)
           48           582          27936
           56          2068         115808
           64          6130         392320
           72           286          20592
           80           822          65760
           88           287          25256
           96           199          19104
          104          2160         224640
          112            93          10416
          120           148          17760
          128           204          26112
          136            71           9656
          144            39           5616
          152           560          85120
          160            99          15840
          168           172          28896
          176           193          33968
          184           331          60904
          192            24           4608
          200            65          13000
          208            14           2912
          216            24           5184
          224            15           3360
          232            12           2784
          240            67          16080
          248            89          22072
          256           608         155648
          384           179          68736
          512           339         173568
          768            40          30720
         1024           468         479232
         1536            35          53760
         2048           319         653312
         3072            51         156672
         4096            55         225280
         6144            15          92160
         8192            37         303104
        12288            53         651264
        16384           135        2211840
        24576            18         442368
        32768            33        1081344
        49152            13         638976
        65536           203       13303808
        98304             9         884736
       131072            27        3538944
       196608             8        1572864
       262144             4        1048576
       393216             3        1179648
       524288             9        4718592
       786432             1         786432
      1048576             1        1048576
      2097152             1        2097152
      8388608             2       16777216
Summary for all pools:
Non-mmapped bytes allocated =    148635648
Number of free chunks       =          335
Max memory footprint        =    148635648
Keepcost                    =     71407904
Allocated memory in use     =     76972304
Free memory                 =     71663344
Re: Cisco ASA connection dropping
Well, it's seems that my Comcast modem was the root cause of the connection dropping out on me.  I've rebooted the modem (had to unplug the built-in backup battery) and my ping times to servers over my VPN improved dramatically.
I'm still concerned about my Cisca ASA memory hanging out at 81-82% usage.  Is this something I can ignore?
Super Bronze
Only thing I can say about the memory usage is that I have never run into situation where memory usage would have become an issue.
Also some old Cisco PIX515 models used to take around 70-90% of the memory when you were using a newer software on them. Dont think we ever run into problems with them though.
You probably need someone from Cisco to answer this question.
- Jouni
I had a nearly identical issue with an ASA5505 on v8.2 / v8.3 a little over a year ago.  Like clockwork my XBL connection would drop.  I thought it was exactly at 15 minute intervals if I was sitting idle, then randomly during gameplay.
* Random Xbox Live disconnects (most while sitting in game menu, some during game play)
* Inaccurate display of friends' online status (50% of friends showing offline or wrong status details)
* Inability to join games of friends (friends I've never had problems joining)
I may be a bit off here, but I believe the fix I put in place was to add a Service Policy Rule for http traffic classification.  As I recall, it was dropping the XBL connection that was initially being established and not properly maintaining state until I added the class-map and access list.  I think the below configs resolved my issue.  192.168.1.99 is the IP of my XBOX.
class-map inspection_http
match access-list acl_inspect
access-list acl_inspect extended permit tcp host 192.168.1.99 any eq www
access-list acl_inspect extended deny ip any any log
2082
