cisco asa control point 100%
Hi All,
What does the 100% below means. Does it indicate that the system is currently under huge cpu intensive load ?
Current control point elapsed versus the maximum control point elapsed for:
      5 seconds = 100.0%; 1 minute: 100.0%; 5 minutes: 100.0% Current control point elapsed versus the maximum control point elapsed for:
  • Firewalling
Yes. It may be. However, you can check the output of Show CPU usage. Normally if the control Point is under 100% the ASA mostlikely would be too.
Have in consideration the following bug:
https://tools.cisco.com/bugsearch/bug/CSCtl91471
If you need further assistance, use the show process CPU usage sorted and paste it here, or open a TAC case.
Mike
Mike
Hi Mike,
Can you please copy and paste the above bug symptom, condition and etc.. i am unable to view this in bool toolkit. It gives Insufficient Permissions to View Bug.
Well I am unable to provide details, however let me know what version are you running into. Along with the output:
ciscoasa(config)# show cpu usage detail
Mike
Mike
firewall# show cpu detailed
Break down of per-core data path versus control point cpu usage:
Core         5 sec            1 min            5 min
Core 0       1.2 (0.0 + 1.2)  2.1 (0.0 + 2.1)  1.8 (0.0 + 1.8)
Firewall Version 8.2(5)
I faced a similar issue and
I faced a similar issue where I can see my ASA Firewall also showing "Current control point elapsed versus the maximum control point elapsed for" 100% and the meaning of this output is not clear, I took help of CIsco TAC to find what does it mean and as per Cisco TAC the 100% is the amount of CPU available to process which is good as per below output.
Core 0       47.8 (0.0 + 47.8)  49.2 (0.0 + 49.2)  50.1 (0.0 + 50.1)
      5 seconds = 100.0%; 1 minute: 99.7%; 5 minutes: 100.0%
CPU utilization of external processes for:
      5 seconds = 0.0%; 1 minute: 0.0%; 5 minutes: 0.0%
Total CPU utilization for:
      5 seconds = 47.8%; 1 minute: 49.3%; 5 minutes: 50.1%
Hi Yogesh, What did TAC say
Hi Yogesh, What did TAC say about this ?
As per Cisco TAC under the
As per Cisco TAC under the output section of commadn "sh cpu detailed" the "Current control point elapsed versus the maximum control point elapsed for:" the <amount>% is the amount of CPU available.
for example in below output the 100% CPU is available for 5 seconds, 99.7% is available last 1 minute and 100% available for last 5 minutes
1013
