Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Cisco ASA disconnect issue
I'm doing some testing here and am facing a issue with the 8.0 OS. when I'm logged in via the management interface and try to re-IP the same interface (with the same IP of course) the ASA disconnects. Is that a known behaviour of the ASA and if it is can someone explain why this would be happening?
1 REPLY
Re: Cisco ASA disconnect issue
I just tested and same thing happens to me.
I did it on the outside interface:
interface gig 0/0
ip address x.x.x.x 255.255.255.0
If I just re-add the same IP to the interface, it briefly disconnects and allow me in again.
I think is normal... is it giving you a problem?
Federico.
143
