Cisco ASA failover active/Stanby Upgrade from 9.1(2) to 9.2.2(4)
Hi All,
I am looking for some insights here... Our last outbound VA has identified some vulnerabilities in our FW. A quick research on the cisco web site has suggested to upgrade from 9.1 to 9.2 to fix the flaw.
I have downloaded the code, I have read the release note(well there isn't much in release note anyway).
But still want a be extra careful though!
HAS anyone here running 9.2.2(4)? is it stable?
And the most important thing for me here, IS ANY CONFIGURATION IS REQUIRED in the actual config file after the upgrade?
Eddy
1 ACCEPTED SOLUTION
Silver
Hi GrandVagabond ,  Normally
from 9.1 to 9.2 .
But as best practice do the upgrade in maintenance window and have a back up of the configuration.
As per this is a failover structure  you must upgrade both boxes.
Hope this helps
Rate helpful post.
- Randy-
1 REPLY
Silver
from 9.1 to 9.2 .
Hope this helps
Rate helpful post.
- Randy-
219
