Cisco ASA failover active/standby
Hi all,
need to ask about implemanting Cisco ASA failover Active/Standby
my question are
1) need to run ASDM on both active/standby same version?? lets say 6.4.5
2) failover link need to used crossover cable?
3) IPS ver need to be same on active/standby
1 ACCEPTED SOLUTION
VIP Green
Yes, this is because the configuration of the Active ASA is copied to the standby ASA.  In the configuration are the settings of which ASDM image to use, so if you have a different ASDM image installed on the standby than the one that is defined in the configuration, the standby ASA will not know where to launch the ASDM from.
No, The default auto negotiation on ASAs use auto MDI/MDIX
Yes and no.  IPS settings do not replicate so you need to manually configure each IPS.  Ofcourse it is recommended to use the same on both.
Please remember to rate and select a correct answer
VIP Green
Hi Marius Gunnerud,
by the way thanks. another questions. my current running unit is 8.0(4) and ASDM 6.3(3). can i know, where to download ASDM ver 6.3(3) for ASA 5510 except another method is copy flash tftp. i try cisco download but dont have this model.
181
