Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Cisco ASA failover issue
Hi Team,
We have three facilities where deployed Cisco 5520 in active/standby mode. In one facility (A) the management tool is showing out of sync for facilty A. But one difference is " sh failover state". Sync done - Standby is missing on the facility A. But sh failover is showing properly. Can anyone help what need to be done to resolve this issue. Below is the output of " sh failover State ".
No sync issue facility
sh failover state
               State          Last Failure Reason      Date/Time
This host  -   Primary
               Active         None
Other host -   Secondary
               Standby Ready  Comm Failure             09:59:18 IST Jul 20 2013
====Configuration State===
        Sync Done
        Sync Done - STANDBY
====Communication State===
        Mac set
Sync issue Facility: A
sh failover state
This host  -   Primary
               Active         None
               Standby Ready  None
        Sync Done
        Mac set
Hall of Fame Super Silver
I suspect at one time the primary unit at your first site was in standby mode and a cosmetic bug is not causing it to revert to the normally expected "sync done" state.
FYI here is an explanation of the output: Table 49-2
Hi Marvin,
Thanks for your inputs. Can you suggest what needs to do to resolve this issue?. Still the NMS tool is showing out of sync for this facility. Some time back the firwalls are rebooted.
Hi Marvin,
Also I am seeing one error on the scondary device.
sh failover history
From State                                               To State                   Reason
18:09:13 IST Aug 27 2013
Standby Ready                                       Cold Standby               Configuration mismatch
18:09:15 IST Aug 27 2013
Cold Standby                                          Sync Config                Configuration mismatch
18:09:30 IST Aug 27 2013
Sync Config                                          Sync File System           Configuration mismatch
Sync File System                                     Bulk Sync                  Configuration mismatch
18:09:42 IST Aug 27 2013
Bulk Sync                                              Standby Ready              Configuration mismatch
That looks normal - it just shows the history and reason for the state being triggered. The final state is "Standby Ready" which was finally reached after the earlier indicated steps due to configuration not initially matching that on the Primary Active unit.
409
