Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
cisco asa ha failover issue
Hi All,
Im facing active standby firewall failover issue once in everyday.
From the logs, it looks like there is a "Comm Failure" and "HELLO not heard from mate", as reasons.
Can someone help me. Logs attached.
syslog:
Failover role switch
Failover mate reports failure
Failover replication start
Failover replication complete
No response from failover mate
day-7
11/7/2014 13:06 Alert 103004 Failover mate reports failure (Primary) Other firewall reports this firewall failed.
11/7/2014 13:06 Alert 104001 Failover role switch (Secondary) Switching to ACTIVE - HELLO not heard from mate.
day-6
11/6/2014 13:10 Alert 103004 Failover mate reports failure (Secondary) Other firewall reports this firewall failed.
11/6/2014 13:10 Alert 103001 No response from failover mate (Primary) No response from other firewall (reason code = 4).
day-6.1
11/6/2014 13:10 Alert 709004 Failover replication complete (Primary) End Configuration Replication (ACT)
11/6/2014 13:10 Alert 709003 Failover replication start (Primary) Beginning configuration replication: Send to mate.
11/6/2014 13:10 Alert 105009 (Primary) Testing on interface XzzzX Status Undetermined
11/6/2014 13:10 Alert 105009 (Primary) Testing on interface XxxxRX Status Undetermined
11/6/2014 13:10 Alert 105009 (Primary) Testing on interface XyyyyyX Status Undetermined
11/6/2014 13:10 Alert 104001 Failover role switch (Primary) Switching to ACTIVE - HELLO not heard from mate.
11/2/2014 16:38 Alert 105009 (Secondary) Testing on interface abcd-interface Status Undetermined
11/2/2014 16:38 Alert 104001 Failover role switch (Secondary) Switching to ACTIVE - HELLO not heard from mate.
11/1/2014 15:24 Alert 103004 Failover mate reports failure (Secondary) Other firewall reports this firewall failed.
11/1/2014 15:24 Alert 103001 No response from failover mate (Primary) No response from other firewall (reason code = 4).
11/1/2014 15:24 Alert 104001 Failover role switch (Primary) Switching to ACTIVE - HELLO not heard from mate.
Hi,How is the
How is the GigabitEthernet0/1 interface connected between the Two Devices which is the fail-over interface.
COMM FAILURE suggests communication issues on this Fail-over interface.
Thanks and Regards,
Vibhor Amrodia
Hi Vibhor,Gig0/1 Failover
Hi Vibhor,
Gig0/1 Failover interface of firewall is directly connected to another firewall interface -- back to back connectivity.
config:-
failover
failover lan unit secondary
failover lan interface Failover GigabitEthernet0/1
failover polltime unit 1 holdtime 3
failover polltime interface 1 holdtime 5
failover replication http
failover link Failover GigabitEthernet0/1
failover interface ip Failover 1.1.1.1 255.255.255.252 standby 1.1.1.2
Hi,Can you check for "show
Can you check for "show crash" on both the units ?
See if the unit might have crashed ?
Thanks and Regards,
Vibhor Amrodia
Hi,Both the firewalls were
Both the firewalls were not rebooted; i have checked the uptime.
461
