Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cisco ASA won't send Syslog out management interface
I have been trying to get my ASA to send syslog out of the management interface without any luck. When I do a packet tracer it says that the global implicit deny rule is blocking it, but I tried to add a permit all in front of it and it still blocks it. Everything is configured correctly from what I can tell and the static routes and routing are correct. This has me baffled. Does anyone know what might be causing this or what I should look at in the config to get this working?
Everyone's tags (3)
VIP Green
Re: Cisco ASA won't send Syslog out management interface
Have you removed the management-only command from the interface?
interface mgmt0/0
no management-only
Please rate all helpful posts.
Please remember to rate and select a correct answer
VIP Green
If you have removed that command, please post a full sanitized running config of your ASA,
Yes, we removed the management-only command and have tried pretty much everything.
VIP Green
could you please post a full sanitized running config of your ASA.
Hi Mark,
      Talking of packet tracer, it would give you correct output for a through the box traffic, not for to the box or from the box traffic.
So firstly we have two questions:
1) Is this a through the box traffic, then you need to permit the traffic through ACL(if from lower sec level to higher) and add a NAT statement(depending on the ASA IOS Version you are using anything above 8.2.5 wont require a NAT).
2) If this is a syslog from the firewall scenario, then you need to make sure to get the following logging configuration on ASA
-enable logging
-logging host management X.X.X.X --------(X.X.X.X is the ip of the syslog server)
-logging trap debugging ----------(debugging is the level, you could use any other too, but to check would sugest this one)
-Further if you have already sorted out till here, get us the following outputs:
-show run
-show logging
-show logging queue
Hope it helps
Cheers,
Naveen
Please Rate Helpful posts.
Hope it helps Cheers, Naveen Please Rate Helpful posts.
988
