Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Cisco ASA5510 Clientless webportal problem
hi.
i have a strange problem.
i have Redundant ASA5510 setup (active/passive)
users have been using IPsec and SSL vpn for a long time without any problem.
now some users want to be able to access bookmarks and company data through the Web portal.
i have enabled Clientless SSL VPN Access, and created a Connection profile, with clientless SSL VPN protocol enabled
when i access to outside of the ASA, im promtet for login, and after succesful login, it starts to download and install the Anyconnect client. and the portal never appers, i have change the option "default post login selection" to go to clientless SSL VPN portal, but i has no effect.
what am im missing ??, i have enabled the service before on other ASA firewall, without any problem, as i recall there`s no need for additional software on the ASA.
i have tried to manuel change the url to https://Domain.domain.dk/+CSCOE+/portal.html , after a succesful login, but it auto changes to
https://Domain.domain.dk/+CSCOE+/noportal.html
Everyone's tags (3)
no comment on this ?
Hopefully you have figured this out by now, its been a few months. I had the same problem. You must disable anyconnect essentials in order to use Clientless VPN. I recommend checking with TAC on your license situation first and also testing to ensure both clientless and client vpn work after you make the change. See the screenshot below.
I hope this helps
Hi Ron,
hi Dan,
I still run into the same problem after adding an AnyConnect Premium Peer License to an ASA which still have
AnyConnect Essentials License.
After configuring clientless vpn I run into the first issue: after successfully login with clientless vpn the anyconnect client downloader starts automatically every time. No matter that in every group-policy the 'Post Login Settings' are configured to 'Go to Clientless SSL VPN portal'.
I spent hours in troublehshooting and nothing helps. Even deleting all group-policies, tunnel-groups and webvpn configuration making the complete configuration step-by-step again is leading into the same problem.
Only when I toggle the 'Post Login Settings' to 'Prompt user to choose' I got the same issue as Dan:
Empty page on https://Domain.domain.de/+CSCOE+/portal.html
Then I found this thread and Rons answer. After disabling anyconnect essentials as Ron wrote the clientless vpn is working.
Many Thanks!
Michael
dear sir
i need help with the clientless web vpn configuration through ASA 5520 with 7.2
I've  done all the configuration on the asa and everything is working but  still a problem with the port-forwarding which is on the client side the  java don't wont to accept the certificate  is there a solution for this  problem
actually my goal for configuring the clientless webvpn is to allow telnet and remote desktop sessions
hope there is an answer
7519
