Cisco ASA5510 v9.1 Allow specific protocols on vlan to outside
Hi there,
I Have an Cisco ASA5510 V9.1 with several VLAN's. One of the VLAN's (VLAN7) is an Guest Network.
I want the Guest network only allow specific protocols to the outside interface. For example only allow http,https,pptp.
Another question is to limit the bandwith on this VLAN7. So for example; i have an 60Mbit internet connection shared over the 7 VLAN's. To prevent VLAN7 to take to much bandwith i want for example a maximum throughput of 2Mbits.
Is this possible and how do i create those rules ?
Robbert
With ASDM it's very easy to create the ACL's in the Vlan7 IF.
ASA can do a policing for specific ACL's (ASDM - configuration - firewall - service policy rules). Also very easy with ASDM
Michael
Please rate all helpful posts
Michael Please rate all helpful posts
VIP Green
Re: Cisco ASA5510 v9.1 Allow specific protocols on vlan to outsi
To limit the bandwidth used by the Guest network you could implemnt something like
the following. The subnet 192.168.1.0/24 represents the guest network and Guest_int
represents the Guest network interface on the ASA.
access-list limit-bandwidth permit tcp 192.168.1.0 255.255.255.0 any eq 80
access-list limit-bandwidth tcp 192.168.1.0 255.255.255.0 any eq 443
access-list limit-bandwidth permit tcp 192.168.1.0 255.255.255.0 any eq 1723
class-map tcp_traffic match access-list limit-bandwidth
policy-map QoS
class tcp_traffic
police output 60000
service-policy QoS interface Guest_int
As for permit only certain protocols to the outside it is just a simple access list that needs to be applied to the Guest interface.
access-list allowed_ports extended permit tcp 192.168.1.0 255.255.255.0 any eq 80
access-list allowed_ports extended permit tcp 192.168.1.0 255.255.255.0 any eq 443
access-list allowed_ports extended permit tcp 192.168.1.0 255.255.255.0 any eq 1723
access-group allowed_ports in interface Guest_int
-- Please remember to rate and select a correct answer
147
