CISCO newbie PORT FORWARDING help
I needed to configure my cisco for port forwrding.
I wanted to use my local IP 192.168.0.10 port 8000 for port forwarding.
I want this to be access on different network.
Please help me on what is the command or what do i need to type on the cisco IOS.
I'm not a 100% clear on what you want to do. But this is portforwarding with NAT:
ip nat inside source list NAT interface overload
ip nat inside source static tcp 192.168.0.10 8000 interface 8000
ip access-list standard NAT
permit 192.168.0.0 0.0.0.255
If you connect to you outside interface on port 8000 you will be directed to 192.168.0.10 on port 8000.
I wanted a web database system on a server computer to be publish on the net...
But I am a newbie to cisco and i don't know the IOS commands for it or what to type.
I will try your commands that you post.
Please if you can answer also my new thread.
https://supportforums.cisco.com/thread/2138335
Thank you
729
