Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cisco PIX 501 with transparent mode Configuration Example
Cisco PIX  501 configuration in tranparant mode
I have ISP modem with Dynamic public IP address
I don't have any public IP address for pix 501 firewall So tell me how to configuration of pix 501 in tranparant mode
My internal IP address is 192.168.1.0 /24 network
Regard
Dinesh Chavan
Contact No 9860051380
dinchavan11@yahoo.com
1 REPLY
Re: Cisco PIX 501 with transparent mode Configuration Example
I refer you to the following command reference on 7.0 http://tinyurl.com/22uhjdv
command for enabling transparent mode is since version 7.0
pix 501 does not support 7.x and later code http://tinyurl.com/2782lmk
In short, firewall mode transparent is not supported on pix 501.
Sorry that it does not help your cause, but hopefully clarifies the pix501 capability.
Maybe you should instead make the modem transparent, or if possible make the pix a pppoe client to your provider http://tinyurl.com/2cumtns
1490
