Cisco PIX 525 Crypto map problem
Good Afternoon,
This setting is correct?
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 auto
interface gb-ethernet0 1000auto shutdown
interface gb-ethernet1 1000auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif gb-ethernet0 intf2 security4
nameif gb-ethernet1 intf3 security6
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname DRP
domain-name mcs.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 5 permit ip 192.168.192.0 255.255.255.0 10.0.0.0 255.255.252.0
access-list 100 permit ip 192.168.192.0 255.255.255.0 10.0.0.0 255.255.252.0
pager lines 24
icmp permit any echo outside
icmp permit any echo-reply outside
mtu outside 1500
mtu inside 1500
mtu intf2 1500
mtu intf3 1500
ip address outside X.X.X.X 255.255.255.240
ip address inside 192.168.192.1 255.255.255.0
no ip address intf2
no ip address intf3
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 192.168.192.0 255.255.255.0 0 0
conduit permit icmp 192.168.192.0 255.255.255.0 any echo
conduit permit icmp 192.168.192.0 255.255.255.0 any echo-reply
route outside 0.0.0.0 0.0.0.0 X.X.X.X 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set SHA-AES-TSET esp-aes esp-sha-hmac
crypto map VPN-MAP 5 ipsec-isakmp
crypto map VPN-MAP 5 set peer X.X.X.X
crypto map VPN-MAP 5 set transform-set SHA-AES-TSET
crypto map VPN-MAP interface outside
isakmp enable outside
isakmp key ******** address X.X.X.X netmask 255.255.255.255
isakmp policy 5 authentication pre-share
isakmp policy 5 encryption aes
isakmp policy 5 hash sha
isakmp policy 5 group 2
isakmp policy 5 lifetime 86400
telnet timeout 5
ssh 192.168.192.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd address 192.168.192.100-192.168.192.200 inside
dhcpd dns 10.0.0.110 10.0.1.110
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd enable inside
terminal width 80
Cryptochecksum:9527d9b93102be492b4d77b84039e758
Jennifer Halim
You are missing NAT exemption and "match address" commands. The rest looks ok as long as it matches the remote end.
nat (inside) 0 access-list 100
crypto map VPN-MAP 5 match address 100
