Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Cisco PIX SIP Issue
Hello All,
I am having an issue with running SIP through my Cisco Pix. A VOIP solution has just been installed, and softphones from the outside are trying to call in using SIP and are failing. The configuration is below. and the code is 6.3 (5). You'll see below that I have the no fixup protocol for sip, as the fixup wasn't working either. Is there something that needs to be configured that I'm missing or could this be a bug in the code? Any other show commands or debug commands I can provide if needed. The call manager server in the below config is 1.2.3.4. Thanks in advance for all your help, you guys are always so helpful.
XXXt# show ver
Cisco PIX Firewall Version 6.3(5)
Cisco PIX Device Manager Version 3.0(4)
Compiled on Thu 04-Aug-05 21:40 by morlee
XXX up 1 hour 45 mins
Hardware:   PIX-506E, 32 MB RAM, CPU Pentium II 300 MHz
Flash E28F640J3 @ 0x300, 8MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is 001c.582b.3c65, irq 10
1: ethernet1: address is 001c.582b.3c66, irq 11
Licensed Features:
Failover:                    Disabled
VPN-DES:                     Enabled
VPN-3DES-AES:                Enabled
Maximum Physical Interfaces: 2
Maximum Interfaces:          4
Cut-through Proxy:           Enabled
Guards:                      Enabled
URL-filtering:               Enabled
Inside Hosts:                Unlimited
Throughput:                  Unlimited
IKE peers:                   Unlimited
This PIX has a Restricted (R) license.
XXXt# show run
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password vQ0/erypfvYyzFoc encrypted
passwd vQ0/erypfvYyzFoc encrypted
hostname DTPIX35thst
domain-name digitaltransitions.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
no fixup protocol sip 5060
no fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list out_in permit udp any host 1.2.3.4 eq 5060
access-list out_in permit tcp any host 1.2.3.43 eq 5060
pager lines 24
logging on
logging buffered informational
logging trap informational
logging queue 2048
mtu outside 1500
mtu inside 1500
ip address outside 4.34.119.130 255.255.255.248
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpn_pool 192.168.100.50-192.168.100.75
pdm location 192.168.1.250 255.255.255.255 inside
pdm location 192.168.1.252 255.255.255.255 inside
pdm location 65.215.8.100 255.255.255.255 inside
pdm location 192.168.100.0 255.255.255.0 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 1.2.3.4 172.20.1.2 netmask 255.255.255.255 0 0
access-group out_in in interface outside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:00:00 sip_media 0:00:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa authentication ssh console LOCAL
http server enable
http 199.96.104.108 255.255.255.255 outside
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
1 ACCEPTED SOLUTION
Silver
Cisco PIX SIP Issue
That maybe the upgrade won´t resolve the issue because the problem could be related to what you have behind the ASA and how it handles SIP
Value our effort and rate the assistance!
Silver
Cisco PIX SIP Issue
Configre the fixup back into the configuration and place debug sip and post the output.
Re: Cisco PIX SIP Issue
Thank You Jumora for the response. I have attached the below dubg output. Any questions please feel free. I look forward to hearing your response.
Silver
Cisco PIX SIP Issue
Do you want to do a skype session juanmh84 is my ID, today am not at work so we can connect through skype
Cisco PIX SIP Issue
I just sent you a message. My userid is japricena, when your free feel free to message back, thanks Jumora!
Silver
Cisco PIX SIP Issue
Hey I left you a couple of IMs on skype
Cisco PIX SIP Issue
Hello Jumora,
I didn't receive any messages. I apoligze my ID is japricena@yahoo.com.
Silver
Cisco PIX SIP Issue
Do you have skype???
Silver
Cisco PIX SIP Issue
Sorry it was for another ticket but if you have Skype we can check this out together
Cisco PIX SIP Issue
Thanks for the prompt response. Yes I have skype and my userid is japricena. I'm online now.
Silver
Cisco PIX SIP Issue
I just tried to call you over skype but you did not pick up, I am going to work at this moment, I will try to see if you are available later today.
Sorry I missed your call, what time are you available today, I'll make sure I'm available? I'm on the east coast timezone.
Silver
Cisco PIX SIP Issue
I am at work and skype is blocked can you give another number.
Silver
Cisco PIX SIP Issue
hey I am going to be at home for the next couple of days so maybe tomorrow we can work on this
Hi Jumora,
No need to troubleshoot this direct issue anymore. The client will be upgrading to an ASA 5505. Is there anything you may know of before I configure the ASA that I need to do to allow SIP through with no issues? Thanks again Jumora
Silver
Cisco PIX SIP Issue
understood. The equipment thats behind the ASA is the ISPs, so if this is the case I will discuss with them, but they are the ones providing the VOIP solution, so it would seem likely the issue is with the PIX itself.
The new ASA 5505 was installed and configured, and there are no more SIP issues. I ensured that SIP inspection was turned on. Thanks jumora for your help!
493
