Cisco remote VPN NAT issue
Dear all,
I am facing an issue , which needs your valuable support.
As per the  attached diagram , remote users are getting ip address 192.168.2.x , internal IP = 192.168.1.x , DMZ ip = 172.16.1.x and 10.0.0.x network is accessed via router connected on DMZ in which i dont have control.
My issue is that remote users want to access 10.0.0.x network but they can't , at the same time they can access DMZ and internal network.
I have tried no NAT as below and i removed first line of ACL as well, but the result is same
access-list 160 permit ip 10.0.0.0 255.0.0.0 192.168.2.0 255.255.255.0
access-list 160 permit ip 172.16.1.0 255.255.255.0 192.168.2.0 255.255.255.0
nat (dmz) 0 access-list 160
i wish to try NATing 192.168.2.x  traffic using a DMZ IP addess when packets are destined to 10.0.0.x.
can some one suggest me on how to proceed ?
Everyone's tags (6)
Re: Cisco remote VPN NAT issue
You need to look at a dynamic policy NAT and nating the VPN users to either the DMZ interface or an address within DMZ range which is dedicated to that purpose.
You could do a :
NAT (outside) 1 192.168.2.0 netmask 255.255.255.0 outside
global (dmz) 1 172.16.1.x
Can you do a packet-tracer and show us the result of that, this will lead us to a nat or something else issue.
The No_Nat configuration is perfect.
Julio
DO rate all the helpful posts
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
i have attached packet tracer output and the firewall config , kindly look in to that .
Hi all ,
As jcarvaja sujested i have tried the NAT config but no luck.
Please provide me a solution .
Here is what I want you to do now:
access-list test permit ip 192.168.2.0 255.255.255.0 10.0.0.0 255.255.255.0
nat (outside) 10 access-list test outside
global (dmz) 10 interface
Let me know the result.
Rate all the helpful posts
841
