Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Cisco Transparent firewall and cisco switch issues.
Dears,
I have a very plain scenario
 LAN cisco switch <2 vlans>  ----------> cisco transparent firwall with bvi interface ------------>  crypto box ---------> cisco router ------ <remote/other site>
i have vlan 61 configured on bvi interface of firewall, crypto box and also on the switch port and vlan of 61 is up up .
The issue is i can connect remotely to cisco transparent firewall but cannot ping or connect to cisco switch. ???????????
Need to know some trobuleshooting tips and basic settings that i need to verify. I simply want lan switch with 2 vlans to pass through the cisco transparent firewall and go to other site/remote site.
Hi,As you are seeing this
As you are seeing this issue with the ICMP through the ASA device , you can check the following:-
1) ICMP inspection or allowing ACLs on the ASA device.
2) Checking the MAC addresses for the switch on the ASA device.
3) Apply captures to see the traffic is passing through the ASA device or not.
Thanks and Regards,
Vibhor Amrodia
Community Member
Well,i have put the
Well,
i have put the inspection icmp turned on for the sessions , and the version i am using is 9.1
moreover, i have put u p the ACLs for inbound and outboudn traffic, and while i ping across the firewall from the inside interface towards outside interface PC, i can see packet counts increasing on the acl , during the show access-llist command.
i have requested the client to verify his part. do let me know further tips if you have any.
[ moreover we cannot try to use packet-tracer from cli in transparent mode ]
Hi,Still you can use the
Still you can use the Packet captures to track if the traffic is passing through the ASA device.
Check this:-
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/110117-asa-capture-asdm-config.html
Thanks and Regards,
Vibhor Amrodia
119
