Clear Blocks Command
I am using a Pix 525 6.3(5) and mistakenly had debugging in place for too long, while troubleshooting some issues. Doing a show blocks, shows the 256 block filled to capacity ,therefore it is not logging correctly, nor can I change the queue setting. Will a clear blocks correct the capacity issue? Also, how does this affect the firewall? Can it be done in a production environment?
Ryan
1 REPLY
Re: Clear Blocks Command
I believe "clear blocks" will only clear the counters. Have you tried turning logging off and back on again?
95
