Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Clear VPN Tunnel phase1/phase2
Is it possible to clear individual tunnels without bringing them all down? I've seen the clear crypt ips sa & cl crypt isa sa, but that's global. Is there something that I can do to pinpoint individual tunnels to kill?
Thanks!
1 ACCEPTED SOLUTION
Re: Clear VPN Tunnel phase1/phase2
If its an ASA, you can also teardown specific tunnels using their index numbers.
To get the index number do "show vpn-sessiondb <(l2l,remote,svc,webvpn)>" command
To log it off do "vpn-sessiondb logoff index " command
-heather
-heather
Hi mate,
You can do it by peer using:
clear crypto ipsec sa peer
Hope that helps!
Anthony
Thats phase2, how about phase1?
I'm not aware of a command that will let you specify for just phase 1 of a peer.
clear crypto session remote will reset phase 1 and 2 though
2610
