Clock-Signal Repair Pictures ISR4300, ASA, ISR4400
Hello!
We have many devices affected by the clock-signal issues.
Cisco does replace the units with repaired/fixed ones.
I have received some ISR4321 routers with the fix applied (pictures attached).
The Cisco provided fix is of - well - mediocre quality (loose solder joints etc..) but works.
I am an EE engineer and am able to fix other routers of my customers as well (attached a picture of one of my fixes).
Spot the difference :)
Is there anyone which has received fixed ASA5506, ASA5508 and ISR4331 routers?
Please post pictures of your fix (hi-res if possible)
I ask because I would like to fix them as well (some of my customers) and avoid configuration, license etc. migration.
I am aware that I might void Ciscos warranty by this act of evil :)
Best regards,
Bernhard
Re: Clock-Signal Repair Pictures ISR4300, ASA, ISR4400
Nobody with a repaired ISR4331?
@cisco QA
Please check your repair process!
Yesterday I received a repaired RMA unit and guess what:
Loose wire (cold solder joint) on your fix which makes it - yes - inactive.
Router will breakdown within month/weeks due to clock-signal-issue.
Is tihs what you want to do?
Is this Cisco quality?
Guess not...
Hi Benhardt, nice hi-res pics ;-)
Thanks for the info, since I plan to purchase one a day off eBay (not for production purposes, of course, but for lab and training - I have to train myself on IOS XR).
BTW, very bad soldering on Cisco's fix, but I think that repair center are more targeted on production volume than in quality - I had a long ago an Asus mobo repaired by one of their centers, it was easy to find that they replaced an SOT23 transistor ... :-/
So, you added a 110R resistor as per EIA-96 marking on 0603 (?) case. Quick question though: on Cisco's fix, they removed R4 (named R4_CLK, 2R2) but you let it in place on you fix. Did you forget to remove it, or is it normal?
Thanks for your answer!
Have a nice day.
R4_CLK is still present on both models.
It's just the bit blurry picture which makes it hard to identify the component.
Thanks for the info. I would have bet to see a via under R4 (upper side of the picture) and rosin (resin) on the opposite side.
Have a nice day.
484
