Cluster ASA configuration without the failover cable
1.How can I make two firewalls cluster without the failover cable. I need to do failover from the inside. Is there any example configuration?
2.Which ports does the ipsec site-to-site vpn configuration use between two asa firewalls?
Regards....
1 REPLY
Re: Cluster ASA configuration without the failover cable
On the ASA there's no need for a failover cable anymore (like PIXes)
You should use a dedicated Ethernet interface for failover communication between both ASAs.
Optionally, if you enable stateful failover, can use another or the same interface.
It is recommended to be the highest-speed interface on the device.
Take a look:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/ha_overview.html
Normally, an IPsec L2L tunnel will use both E0 (outside) interfaces on the ASA.
Federico.
637
