communication between PiX internal interface
hi,
i am using a Pix firewall for hiding my two internal networks( for ex network A and B) connected to seperate interfaces of the PIX firewall.
a) i installed one windows server on
network A , and it's working properly for Network A users.
b) i want to share this windows server for users in Network B. i am not able to achieve this , perhaps i have to open PiX firewall as Network A & B are on two seperate interface.
Please guide me for a sample cisco config Or suggest.
Thanks,mahesh.
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: communication between PiX internal interface
Mahesh
You can do this one of 2 ways.
1) If the 2 interfaces are the same security level you can use the following command
"same-security-traffic permit inter-interface"
if you do this traffic an flow freely between the 2 interfaces without any access-lists or NAT.
2) If you would rather control traffic. It all depends on which interface has a higher security level.
Can you post the security levels for the 2 interfaces. You can get these from a "sh run"
Jon
Hi Mahesh
What version of Pix are you running ?
What security levels do each of the interfaces have ?
Jon
dear jon,
it's 7.1 and pix configured as basic firewall ( no VPN ) , so the question is how to open one interface for another in a pix firewall.
rgds,mahesh.
Mahesh
Jon
dear Jon,
Appriciate your help.
your question on security level help me to fix the problem and i got a sample config
showing the config from low security zone to
high security zone.
Tks,mahesh
can post sample Config here, more or less iam in the same situation .
Tks
karthik
216
