Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
conduit replacement
how is function dhe new pix's without the conduit function?
thanks
Hall of Fame Super Blue
Re: conduit replacement
Conduits have been replace by access-lists on the pix. You still need NAT etc. but you allow access by creating access-lists and applying them to interfaces eg
access-list outside_in permit tcp any host 194.32.5.1 eq www
access-list outside_in permit tcp any host 194.32.5.2 eq https
access-group outside_in interface outside
This would allow http from outside of your pix through to 194.32.5.1 and https traffic from outside to 194.32.5.2.
Jon
Community Member
any book? only for ACL on pix's?
thanks
Not sure you need a full book. Attached is a link to config guide for pix 6.3 for the chapter on configuring access-lists. Pix v7.x will be pretty much the same.
http://www.cisco.com/en/US/docs/security/pix/pix63/configuration/guide/mngacl.html#wp1068801
Jon
Community Member
I have the Cisco Press Study guide for the SNPA exam 642-522 which has an entire section on ACLs on PIX.
I believe there is also a tool on the Cisco website that will convert configurations with conduits to ACLs to save some work.
You can still do Conduits if you want (the PIX will support them) - however, it is recommended that you do not use Conduits if you're using ACLs because ACLs will take precidence over conduits.
Gold
here's a tool that will convert conduits to ACL's...
http://www.cisco.com/cgi-bin/tablebuild.pl/pix
download the occ... file
Community Member
I have a suituation that i need to convert all my conduit to ACL..will abv mention tool is ok..
satesh
440
