Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Config Help
I just added a PIX515E to my lab (since this is a lab, if I need to change IP address, that is not a problem)....I thought I configured it right, but I am not able to ping any of my other routers/PCs.
I have EIGRP on the other three routers, but not sure if I configured it right on the PIX.
The diagram below shows my current network topology....(right now the PIX is connected vai Ethernet 1 to the switch, not the router itself)
Please help:
PIX Version 8.0(4)32
hostname PIX515E
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet1
nameif inside
security-level 100
ip address 192.168.4.1 255.255.255.0
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
ftp mode passive
object-group icmp-type ICMP-INBOUND
description Permit necessary inbound ICMP traffic
icmp-object echo-reply
icmp-object unreachable
icmp-object time-exceeded
access-list INBOUND extended permit icmp any any object-group ICMP-INBOUND
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
router eigrp 1
network 192.168.4.0 255.255.255.0
route inside 0.0.0.0 255.255.255.0 192.168.2.1 1
route inside 192.168.2.0 255.255.255.0 192.168.4.0 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart
snmp-server enable traps syslog
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd ping_timeout 750
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
prompt hostname context
Cryptochecksum:05e5f0b9295e728c54e57736f278d283
: end
PIX515E#
Config Help
Hello Jonathan,
So the diagram is not that clear as you said the connection from the pix goes to the switch and no the router!
Now the pix is connected on the outside to a modem or a dhcp server device so you have the default route pointing to the wrong interface, it should be route outside no inside I guess:
Now you are also using EIGRP, you are just publishing the network 192.168.4.0 witch is where the other EIGRP neighbors are so the config is fine.
Now if you cannot ping the directly connected devices you are troubleshooting the wrong device as per your configuration witch is really basic is good for your requirements
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Config Help
Ok, let me clear up what I am trying to do:
The diagram is accurate except for the PIX...All address are correct.
Cable Modem----->Pix----->Cisco 3640----->Cisco 3745-----Cisco 2610
Pix:
Ethernet 0 - Outisde
Ethernet 1 - Inside (192.168.2.4)
Cisco 3640:
Ethernet 0/0 - Connection to Pix (192.168.2.6)
For the EIGRP to work what networks do I need to put in the network statement enable to ping all devices on the network?
Below are the config for the rest of the network?
3640:
Current configuration : 1856 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname 3640-Internet
boot system flash c3640-ik9s-mz.122-40a.bin
username woodjl1650 privilege 15 password 0 henry999
memory-size iomem 25
ip subnet-zero
ip cef
ip domain-name www.jkkcc.com
ip name-server 192.168.2.127
ip name-server 192.168.2.128
ip dhcp excluded-address 192.168.2.1 192.168.2.150
ip dhcp pool 192.168.2.0/24
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 192.168.2.127 192.168.2.128 8.8.8.8 127.0.0.1
call rsvp-sync
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
ip address 10.0.1.9 255.255.255.252
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
ip address 10.0.1.5 255.255.255.252
interface Ethernet1/0
no ip address
shutdown
half-duplex
interface Ethernet1/1
no ip address
shutdown
half-duplex
interface Ethernet3/0
no ip address
shutdown
half-duplex
interface Ethernet3/1
no ip address
shutdown
half-duplex
router eigrp 1
network 10.0.0.0
network 192.168.0.0
network 192.168.2.0
no auto-summary
ip nat inside source list 15 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.2.128 80 interface FastEthernet0/0 80
ip nat inside source static tcp 192.168.2.128 25 interface FastEthernet0/0 25
ip classless
ip http server
ip http authentication local
access-list 15 permit 192.168.2.0 0.0.0.255
snmp-server community public RO
snmp-server community private RW
snmp-server enable traps tty
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
end
3745:
Building configuration...
Current configuration : 1531 bytes
version 12.4
hostname 3745-Internet
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.150
ip dhcp pool 192.168.1.0/24
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
ip domain name www.jkkcc.com
ip address dhcp
ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
ip address 10.0.1.6 255.255.255.252
no fair-queue
clock rate 2000000
ip nat inside
ip route-cache flow
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
router eigrp 1
network 10.0.1.4
network 192.168.1.0
no auto-summary
ip forward-protocol nd
ip route 192.168.2.0 255.255.255.0 192.168.20.0
ip http server
access-list 15 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
2610:
Current configuration : 985 bytes
version 12.3
hostname Router
boot-start-marker
boot system flash
boot-end-marker
no logging on
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.3.1 192.168.3.150
ip dhcp pool 192.168.3.0/24
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
interface Ethernet0/0
ip address 192.168.3.1 255.255.255.0
half-duplex
interface Serial0/0
ip address 10.0.1.10 255.255.255.252
clock rate 2000000
interface Serial0/1
no ip address
shutdown
router eigrp 1
network 10.0.0.0
network 192.168.3.0
no auto-summary
no ip http server
ip classless
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
Config Help
Hello Jonathan,
Only the 192.168.2.0/24
Can you ping the 3745 from the pix ( they are directly connected so they should)?
Julio Carvajal
Config Help
No I can't ping any network.
PIX - Config:
hostname PIX515E
names
interface Ethernet0
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
shutdown
nameif DMZ
security-level 50
ip address 192.168.4.2 255.255.255.0
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
mtu DMZ 1500
no failover
arp timeout 14400
router eigrp 1
telnet timeout 5
ssh timeout 5
console timeout 0
Cryptochecksum:9251654182c76b63f56201b20219052a
: end
Config Help
Hello Jonathan,
I do not understand, on the first post you only have 2 interfaces now you have 3!!
Why are they on the same subnet!!
router eigrp 1
So outside interface network is 192.168.2.0 and inside interface network is 192.168.4.0
Please check the status of the interface on the ASA and the directly connected device.
I need the ASAs inside ip address ( the right one not 2 of them as on this post) and also the ip address of the device directly connected to the ASA...
Because as I can see the Cisco 3640 is not on the same subnet than the ASA
3640 ip :
Julio Carvajal
Config Help
I am just trying to troubleshoot, trying to figure out how to get this device to work right.  Like I stated in the begining this is a home lab, so no IP address is firm.  I am trying different IPs out until someone can help me with the config.
What IP subnet should I use for the PIX?
Config Help
Hello Jonathan,
If we troubleshoot it and each single post you change it there is no future on this discussion..
The same one that you have on the device directly connected, so they can exchange hello packets,EIGRP packets, etc,etc.......
Julio Carvajal
Config Help
Ok, IP address will be 192.168.2.5.
Config Help
Sure,
Let me know if you can ping the directly connected device!!
Do rate all the helpful posts!
Julio Carvajal
Config Help
Still not able to ping from my PC (192.168.2.122) to the PIX (192.168.2.5) also can't ping from PIX to 3640 (192.168.2.1)
Current show run:
hostname PIX515E
names
interface Ethernet0
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
ip address 192.168.2.5 255.255.255.0
interface Ethernet2
nameif DMZ
security-level 50
ip address 192.168.2.6 255.255.255.0
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
mtu DMZ 1500
no failover
arp timeout 14400
router eigrp 1
telnet timeout 5
ssh timeout 5
console timeout 0
Cryptochecksum:68f53bfe67a6272a7406881d204a69d4
Config Help
Provide:
show interface ip brief on the pix
and sh ip interface brief on the 3640
Julio Carvajal
Config Help
PIX: - Not sure why is says IP address uassigned.... any idea?
So looking at this, my connection could be wrong - PIX Ethernet 1 connected to Switch, does it need to be connected directly to the 3640, if so, what type to cable? Roll-Over, Crossover or straigh through?
PIX515E# show interface ip brief
Interface                  IP-Address      OK? Method Status                Protocol
Ethernet0                  unassigned      YES DHCP   down                  down
Ethernet1                  unassigned      YES manual up                    up
Ethernet2                  unassigned      YES manual down                  down
Ethernet3                  unassigned      YES unset  administratively down down
Ethernet4                  unassigned      YES unset  administratively down down
Ethernet5                  unassigned      YES unset  administratively down down
3640:
3640-Internet#show ip interface brief
FastEthernet0/0            68.224.240.31   YES DHCP   up                    up
Serial0/0                  10.0.1.9        YES NVRAM  up                    up
FastEthernet0/1            192.168.2.1     YES NVRAM  up                    up
Serial0/1                  10.0.1.5        YES NVRAM  up                    up
Ethernet1/0                192.168.4.10    YES manual up                    down
Ethernet1/1                unassigned      YES NVRAM  administratively down down
Ethernet3/0                unassigned      YES NVRAM  administratively down down
Ethernet3/1                unassigned      YES NVRAM  administratively down down
3640-Internet#
Config Help
You can connect it to the switch, but as you can see the unassigned is the issue
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
nameif DMZ
security-level 50
no ip address 192.168.2.6 255.255.255.0
Julio
Julio Carvajal
345
