Configuration Help
I have attached my firewall config.
I am replacing my Pix515 with a new ASA5510 and Im having some issues.
First thing between the Inside to all other interfaces I know that inside can get to any lower Security interface.
I am testing ping from DMZ to Inside and it seems taht I can ping and browse all ports and such from DMZ to Inside and I dont understand why. I have specific ACLs and have the ACL applied to the correct Interfaces.
  • Firewalling
1 REPLY
Re: Configuration Help
My goal is to protect the Inside network from all lower security network such as DMZ, and Outside. But from a quick test I can ping from the DMZ into the lan and from the Lan To the Dmz. Also from the Inside network I can browse to a website in the DMZ and from DMZ back to inside.
I dont see what I am doing wrong in my configurations.
106
