configuration management interface
I try to set a IP adress for the interface of mamangement 0/0, i work on ASA  5525-x, but i not find the command ip adress withen i am on the interface of mamangement 0/0
2 ACCEPTED SOLUTIONS
VIP Green
are you trying to configure
are you trying to configure the firewall in transparent mode?  If so, the management IP is configured under the BVI interface.
Please remember to select a correct answer and rate helpful posts
-- Please remember to rate and select a correct answer
VIP Green
Do you require further
Do you require further assistance with this issue? if not, please mark the question as answered.
VIP Green
Hello, Thanks for your answer
Thanks for your answer.
indeed,
My colleague has set me in multiple context mode, you must  back
in mode signl
VIP Green
41
