Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
configure asa5520 failover help
I am trying to configure my two asa5520 (v7.2(1))
my purpose is:
asa5520-A asa5520-B
context-A primary secondary
context-B secondary primary
I have configure the asa5520-A and it worked. So, I go to asa5520-B and enable failover with "failover lan unit secondary" and the configuration of asa5520-A was automatically copied to asa5520-B.
on show failover (on both machines), I find the asa5520-A active on both contexts and asa5520-B failed on both.
I tried to powder off the asa5520-A, and the B did take over. But, it complained there is no route to local network.
Please anyone can advice me how to configure the failover and how to fix the no route problem. - it seems I can not configure the B box, since it is secondary.
Any comments will be appreciated
Thanks advance
1 ACCEPTED SOLUTION
Silver
Re: configure asa5520 failover help
You can refer to following link, which explains how to configure Active-Active failover:
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_7_2/conf_gd/general/failover.htm#wp1096075
1 REPLY
Silver
363
