configure dual isp for failover on asa 5505
guys,
how do you configure firewall when one of the isps is dynamic? primary internet is static and secondary internet is dynamic
i setup 3 vlans, 2 outside vlans and 1 inside vlan. i specify route command for the outside vlan with the track, but i don't know how to setup route command for the dynamic ip. i also configure sla command. whenever the primay is not connected the secondary doesn't work, but i have no problem if connecting directly to with laptop.
let me know your thoughts.
thank you in advanced guys.
2 ACCEPTED SOLUTIONS
Can you do something like this:
sla monitor 123
type echo protocol ipIcmpEcho 8.8.8.8 interface outside
num-packets 3
frequency 10
sla monitor schedule 123 life forever start-time now
track 1 rtr 123 reachability
route outside 0.0.0.0 0.0.0.0 10.10.10.1 1 track 1
sla monitor 225
type echo protocol ipIcmpEcho 8.8.8.8 interface outsidebackup
num-packets 3
frequency 10
sla monitor schedule 225 life forever start-time now
track 2 rtr 225  reachability
interface Vlan3
nameif outsidebackup
dhcp client route track 2
dhcp client route distance 25
ip address dhcp setroute
Hello David,
Excellent, I did not tough about the DHCP client route option (Kudos to you )
Now, I would agree with your configuration except with the SLA 225.
I mean why would track the route through VLAN 3.
As soon as the ASA primary is back and running preemption will take place.
So the configuration you need as David suggested will be:
sla monitor 123
num-packets 3
frequency 10
interface Vlan3
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Tedy,
They provide you dynamic IP address for the outside interface ? Is that what you are saying?
or are you saying that there IP is dynamic?? cause they will need to provide you with a defined gateway IP for this to work.
Jcarvaja
Julio Carvajal
Hi Julio,
Yes, they provide me with dynamic ip address. so it looks like this, I don't know how to make the route fail automatically since the second ISP is dynamic.
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 3
interface Vlan2
nameif outside
security-level 0
ip address 10.10.10.10 255.255.255.0
interface Vlan3
security-level 0
sla monitor 123
num-packets 3
frequency 10
Re: configure dual isp for failover on asa 5505
Hello Tedy,
The IP address you get is dynamic but can you talk to them about this implementation so they can let you know if it's possible to have the same default-gateway (their IP address) ??
Jcarvaja
Julio Carvajal
sla monitor 123
num-packets 3
frequency 10
sla monitor 225
num-packets 3
frequency 10
interface Vlan3
Hello David,
sla monitor 123
num-packets 3
frequency 10
interface Vlan3
Jcarvaja
Julio Carvajal
Good point.  I was thinking about a situation I worked on where I was using the dhcp address as a primary route out and then failed back to my static route.
David and Julio,
Thank you for both your inputs. I will try your approach.
Hello Tedy,
Excellent, in the mean time you can rate all of our answers,
Jcarvaja
Julio Carvajal
442
