Configure SA520 firewall for 2 ISP (cable & ADSL)
hi
Is it possible and howto configure Cisco SA520 firewall for 2 ISP (cable & ADSL) to get load balancing between these ISP?
THX
Everyone's tags (6)
Please refer to the below forum link as this will help you resolve you query.
https://supportforums.cisco.com/docs/DOC-15622
let me know if that help or you need any further assistance.
Thx, but that means is it possible to configure dual ISP (Loadbalancing) on SA520 firewall?
Load-balancing is not suported as the ASA does not supports PBR. You can  try to do some work-arounds to send some traffic from one link but this is not cisco supported. I have seen scenarios about this working so if you really need it you can give it a try.
Julio
Do rate all the helpful posts
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
720
