Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Configuring a pix to use port 2000 for FTP
I am trying to configure a pix to use port 2000 for FTP. How can this be done? this is a 515E with 7.0
thanks
1 ACCEPTED SOLUTION
Re: Configuring a pix to use port 2000 for FTP
Port 2000 is Skinny, and you won't get ftp through it unless you disable skinny inspection on the fw.
no inspect skinny
Are you hosting the FTP server on the inside or DMZ? Is it listening on port 2000 or the default 21?
Community Member
The FTP server is on the DMZ and the clients are on the Inside. Other hosts within the DMZ are able to access the FTP server using port 2000. The Inside interface has a higher security level that the DMZ so Inside hosts should be able to access the DMZ without an access list. The FTP server is listening on port 2000, my config so far is
class-map ftp-class
match port tcp eq 2000
policy-map global-policy
!output omitted
class ftp-class
inspect ftp
service-policy global-policy global
thanks
Do you have an access list on the inside or DMZ interface that would block port 2000? Does other communications work between the 'inside' and the 'dmz'?
Green
If you have no communication between the inside and dmz, you probably need something like...
static (inside,dmz)
no inspect skinny
167
