Configuring Control Plane ACL on ASA
I configure a control plane ACL to a outside interface for limiting AnyConnect access on ASA 5520, will enter the following commands on the device:
! interface GigabitEthernet0/0
!  nameif outside
!  security-level 0
!  ip address 1.2.3.4 255.255.255.252
access-list LimitingAnyConnect extended permit tcp host 5.6.7.8 host 1.2.3.4 eq https
access-group LimitingAnyConnect in interface outside control-plane
Does this configuration allow ONLY 5.6.7.8 to connect AnyConnect on the device?
Should I add the following ACL?
access-list LimitingAnyConnect extended deny tcp any host 1.2.3.4 eq https
Thank you for your cooperation in advance.
Everyone's tags (3)
1 ACCEPTED SOLUTION
No, you don't need to specify the "deny" access-list because by implicit rule is deny ip any any if you have configured an access-list on the interface.
1 REPLY
1165
