Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Connect from DMZ Web Server to SQL Cluster Virtual IP through PIX
Hello - I'm having connectivity issues while attempting to connect to the internal sql cluster name or ip address from my web server on the dmz, although I am able to get to one of the servers in the cluster directly via its name/ip, but not to the other. I have tcp 1116, 1433, 135, icmp and netbios-ssn, ns(udp) permitted. any suggestions would be greatly appreciated.
1 REPLY
Re: Connect from DMZ Web Server to SQL Cluster Virtual IP throug
Hi ..
Cluster and that staff is not my thing .. but I suggest you checking the ARP table on the ASA and any switches between the DMZ and the SQL to make sure there is an entry for the Virtual IP and its respective MAC address ( I believe it might be a multicast MAC address beginning with 01-00-5E .. ). Assuming you have allowed access from the DMZ to the servers .. you should be at least be able to access both by their physical IP address and so that is another thing I suggest you checking first.
This article might give you a hint of what I mean !!
http://support.microsoft.com/kb/193602
I hope it helps .. please rate it if it does !!
348
