Connecting Cisco ASA TenGig to Nexus 7000
I am attempting to connect an ASA 5585 TenGig to a Nexus 7000 F2 TenGig port.
I am seeing the error message Transceiver validation failed when I insert the SFP into the port.  I know that the error is removed when I enter the command switchport mode fex-fabric, and have tried the configuration, but am unable to get the link to come up.at either end. I am also aware that LACP is not supported when switchport mode fex-fabric is configured.
ASA is in multiple context mode with portchannel interfaces allocated to the relevant ASA context.  Anyone know if I am overlooking something?  Anyone run into this issue before?
Nexus 7000:
Eth1/1       1       eth  access down    Transceiver validation fa  auto(D) 2
Eth1/2       1       eth  access down    Transceiver validation fa  auto(D) 2
interface Ethernet1/1
  switchport mode trunk
  switchport trunk allowed vlan 1-10
  channel-group 2 mode active
  no shutdown
interface Ethernet1/2
  switchport trunk allowed vlan 2-10
  no shutdown
interface port-channel2
ASA5585:
interface TenGigabitEthernet0/6
interface TenGigabitEthernet0/7
interface Port-channel2
interface Port-channel2.2
vlan 2
interface Port-channel2.3
vlan 3
context inside
  allocate-interface Port-channel2.1
  allocate-interface Port-channel2.2
  config-url disk0:/inside.cfg
Everyone's tags (2)
Hall of Fame Super Silver
On the F2 cards with 1/10 Gbps-capable ports you sometimes have to add "speed 10000" to validate the 10 Gbps transceiver.
In my case, I was getting this error on a interface of a Nexus C6001 with the FET-10G transceiver.  I was able to clear it up by temorarily replacing and configuring a slower GLC-T which worked as expected.  I then removed all the settings an got the FET-10G to link.
Sorry for the very late reply.  It turned out that I had not allocated the F2 interfaces to the VDC
Thanks for your replies
755
