connecting to ASA5510 with GUI
i have a asa 5510 band new i ve been trying to get configure it with HTTPS with a web browser and nothing is showing just the same page cannot be displayed ive got the ip address configure properly, i can not understand what the problem is. please someone out there help. i have got to have this box up and running by weekend. thank you
Re: connecting to ASA5510 with GUI
Hi Eric,
first make sure you have ip connectivity to inside interface ip of fiirewall, if pinagle from your PC go to next check bellow.
make sure your fw is allowing management access for your PC IP address or subnet.
e.i
asa(config)#http mask
for allowing a subnet access say 10.20.20.0/24 on interface called inside
asa(config)#http 10.20.20.0 255.255.255.0 inside
or by just ip source say 10.20.20.2 is your PC
asa(config)#http 10.20.20.2 255.255.255.255 inside
same format applies for telnet and ssh
telnet 10.20.20.0 255.255.255.0 inside
etc..
also make sure http server is enabled
e.i
asa(config)#http server enable
regards
hello
i just tried configuring the ASA with the
ip http ip add subnet inside command the ASA has an ip add of 1 while my pc has an ip of 150 of the same subnet i cant seem to be able to connect to the ASA with the web browser. am now trying to use command line. help !!!!!
Pls use cli to setup initial management connectivity, can you confirm you can ping the inside interface ip of fw from 150.
Use the example script I provided through cli.
let us know if still problems to help u, also if you could post the output of show version to make sure you have asdm image installed in fw.
Please post config.
hi
what do u mean that post the config
Log into the ASA via telnet, ssh, or console and issue the command "show run". Copy the entire output and paste here.
3984
