Connection failing on PIX 515 6.3(4)
Need some help here
Basically I have users coming in from the "clients" interface with Security level 0 and IP address 192.74.X.X/16 to a server on the dmz-client with security level 40 and ip address of 202.180.251.93/32 but the connection is failing even though there is an access-list allowing it from the "clients" interface, static (dmz-client, clients) and route configured. I have attached the PIX configuration and the failure logs as well.
Hope anyone can shed some light on this issue.
1 REPLY
Re: Connection failing on PIX 515 6.3(4)
Can't see anything obviously wrong in your config. Where did you say those error logs were? I'd like to see the syslog generated when this is refused.
102
