Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
connection limits on ASA
we have an ASA 5520 & 5540. my understanding says the connection limit on 5520 is around 120000 connections.Please correct if this is wrong.
got certain doubts on connection limits:
- does this mean limit on tcp or udp or both
- what happens if it exceeds the limt, drops the connections or hangs the firewall
- any way to check what is the max limit and the current usage on the firewall
Thanks in advance!
1 REPLY
Re: connection limits on ASA
For ASA 5520, the maximum connections are 280,000 (inc. all traffic).
To check for the current connections: show conn count
Here is the specs on ASA series:
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
Hope that helps.
1473
