Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Connection/Performance Problems after 6.3 to 7.2 upgrade
Here is config on PIX515E wiht 7.2.2.
[The old config with 6.3.4 worked fine.]
After upgrade, access from outside stopped working. Here is the config with 2.2.
Any help? Thanks,
fw# sh run
: Saved
PIX Version 7.2(2)
hostname fw
interface Ethernet0
nameif outside
security-level 0
ip address
interface Ethernet1
nameif inside
security-level 100
ip address
interface Ethernet2
nameif intf2
security-level 4
no ip address
ftp mode passive
access-list 111 extended permit tcp any host eq 7700 log
access-list 111 extended permit udp any host eq 6600 log
icmp unreachable rate-limit 1 burst-size 1
global (outside) 1 interface
nat (inside) 1
static (inside,outside) tcp 7700 7700 netmask
static (inside,outside) udp 6600 6600 netmask
access-group 111 in interface outside
route outside 1
route inside 1
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect http
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect sip
inspect xdmcp
service-policy global_policy global
Re: Connection/Performance Problems after 6.3 to 7.2 upgrade
Not sure if this is the issue or not, but a couple of things:
1) Your default route next hop is not on the same network as your firewall.
Your netmask on the outside interface ( means that the only IP addresses that it can reach are -, with being the broadcast. However your default route
route outside 1
Says that the next hop is, which wouldn't be on the same network, unless you change the netmask.
Similarly, I'd check netmask on the inside interface to make sure you really want a (8 Class Cs) local to that firewall interface.
Also - I'd check the log for any suspicious log entries - are you getting anything indicating no route
Please rate this message if it helps solve some or all of your issue.
Community Member
It was typo, subnet mask should be for outside interface.
Jason, thanks for reply. Do you have any idea?
Everything was ok after downgraded back to 6.3.4.
