Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Connection time out questions.
I have a pix 515e running 7.1(2)7.
I had been getting connection time out after 5 hours but don't know where the 5 hours come from as the default setting is 3 hours and had not been changed.
** Default timeout on Pix firewall.
PIX# sh run timeout
timeout xlate 3:00:00
timeout conn 3:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
** Firewall log showed connection tear down after 5 hours.
2007-04-30 09:29:39 Local4.Info PIX %PIX-6-302013: Built outbound TCP connection 10249505 for DMZ1:10.186.121.35/50000 (10.186.121.35/50000) to inside:10.186.3.59/2713 (10.186.3.59/2713)
2007-04-30 14:33:49 Local4.Info PIX %PIX-6-302014: Teardown TCP connection 10249505 for DMZ1:10.186.121.35/50000 to inside:10.186.3.59/2713 duration 5:04:19 bytes 796 Connection timeout
1 REPLY
Re: Connection time out questions.
The idle timeout mean that there is no activity at all for 3 hrs.
But connection can be open for more that 3 hours if there is still activity.
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_command_reference_chapter09186a00801727ae.html#wp1026093
sincerely
Patrick
177
